× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Can I swap SIM cards between NightHawk MR1100 and LTE Modem LB11230
N4KHQ
I have a prepaid AT&T SIM Card working in a MR1100 Hotspot. If I order a LTE LB1120 Modem and install the card will it work or will I have to contact AT&T? Thanks
Model: LB1120|4G LTE Modem, MR1100|Nighthawk M1 Mobile Router
Message 1 of 2
bigblue1
Tutor
Re: Can I swap SIM cards between NightHawk MR1100 and LTE Modem LB11230
In general, swapping SIMs to a comparable type of device should work. I've heard of folks having success moving a SIM from a Mobley to other hotspots like a Unite Explore or Netgear Nighthawk M1. But AT&T has certainly done things to try to prevent that, such as SIM locking on Mobleys or tying a device's IMEI to your account and only allowing that. You'd either have to do research to find someone else who has done what you're trying to do (recently) or just give it a try yourself.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3738 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
