- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can I use AirCard without its battery ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello evevryone.
As it seems to be impossible to contact Netgear BEFORE buying one of their product to get information, I'm here.
So the question is simple : Can the AirCard 785 (French model, dunno if it's important) work on AC power (230V in France) with its battery completely REMOVED !
I know the question may appear weird, but I've used a smarthphone (with removable battery) for 6 months 24h/7days on AC power, and as the smartphone didn't work without its battery even on AC power, I should have left the battery inside the smartphone, and it became a ballon and finally died ... yes in 6 months ...
I think it was extremely stupid from the smartphone builder to force the presence of battery ... but it's surely because they wanna make customers buy another smarthpone or battery quicker ...
Anyway I'd like to avoid the same trouble with AirCard. If you have a reliable source, I'd be very glad.
Thank you in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can I use AirCard without its battery ?
Hi...
Successfully tested with AC785 and AC810. Both work fine with AC power connected and battery removed.
This also works if the AirCard Cradle is providing power.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
