Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Connecting multiple Ac750 s to Nighthawk M1
Gniff19
Hoping this is the right location to ask !!
Installed an M1 and looking to extend Wi-Fi coverage using Powerline in multiples (2 possibly 3).
1/ Can’t figure out if AC750 has a sender box or connects via WiFi to create the extension/access point. Ie do I need to Ethernet from the M1 to a sender (PL1000?) or its all wireless!!
2/ it isn’t clear, Netgear install sheets are unclear (or I’m stupid), if I could establish two differing access points on the same M1 WiFi hub using two AC750s called House/Cottage ?
Any help appreciated as moving from the wired to wireless world !!!
Thx … Stu
Message 1 of 5
Accepted Solutions
Guru
Re: Connecting multiple Ac750 s to Nighthawk M1
A couple of things.
1. AC750 usually denotes 300mbps on the 2.4ghz and 450mbps on the 5ghz. But that's just link speed, not actual throughput. Throughput on the 2.4ghz tends to be 20-40mbps on those style devices.5ghz maybe 100-200mbps if you've got a good signal.
2. @michaelkenward suggestion of just getting straight powerline devices and connecting a mesh system might be a better option. A little more expensive but easier to use for walking through the home
3. another option is if you have coax ran throughout the home already would be MoCa adapters (ethernet over coax). The new 2.5 version has quite decent throughput. Might also be an option.
Message 5 of 5
All Replies
Guru
why not pickup a renewed triband mesh system?
The powerline devices haven't been updated in a long time and they're not mesh.
Message 2 of 5
They can be if you use them just as a bit of wire that does the wired backbone for a network.
It works here with an MS90 satellite connect to a mesh router MR90 with PL1000s.
Message 3 of 5
Gniff19
Thx both for such quick replies, we can’t cable as 3ft thick walls and our guests phones/tablets linkage will not be wired. so logic was Wi-Fi plug onto the ring-main (wire) to create WiFi ‘repeaters’/access points linking to the M1. The alternative is pulling down ceilings and very big drills !!!
Current max mb connection is 4G @ 120mb/s, so even AV750s are potentially overkill as their throughput 350 - 400mb/s! But if/when the Mb signal is upgraded to 5G we’ll still be ok !🤞
AC750s are currently £25 ($30) in 🇬🇧, mesh is £000s. So Michael do you think I would need a PL1000 in addition to the AC750s or would they link to the Nighthawk M1? Thx … Stu
Message 4 of 5
Guru
A couple of things.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1118 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
