× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Data Usage Nighthawk M1 again
PPolly
Tutor
Have updated my router and it is now showing "detecting service" instead of data usage. I had installed version 12.06.02.00
I know this has been a problem in the past but the prior solution is now outdated as my device wont let me download the version suggested in that solution.  HELP
Model: DGND3700v1|N600 WIRELESS DUAL BAND GIGABIT ADSL2+ MODEM ROUTER
Message 1 of 8
IrvSp
Master
Re: Data Usage Nighthawk M1 again
You are in the wrong forum. This is a Netgear Nighthawk Wireless Router forum. Go back to Community, then select HOME, and chose which fits your problem. Can't even tell you which to use as the subject mentions M1 and the footer is completely different. None are Nighthawk wireless routers.
Message 2 of 8
PPolly
Tutor
This is the router I have, DGND3709v1
Model: DGND3700|N600 WIRELESS DUAL BAND GIGABIT ADSL2+ MODEM ROUTER
Message 3 of 8
Blanca_O
NETGEAR Employee Retired
Hi @PPolly
Welcome to NETGEAR Community!
Can you please confirm first the model number of your NETGEAR device? Do you have a ADSL modem/router?
Blanca
Community Team
Message 4 of 8
PPolly
Tutor
Hi Bianca, I have a DGND3700v1, wireless nighthawk ist model
Message 5 of 8
PPolly
Tutor
Sorry, confused my two netgear routers, the mobile nighthawk M1 is the one I am having trouble with even though I have updated with the latest Telstra firmware patch
Model: MR1100|Nighthawk M1 Mobile Router
Message 6 of 8
That's one of the Mobile Routers, Hotspots & Modems. You might get better and quicker replies, and find other answers, over in the appropriate section:
Message 7 of 8
Blanca_O
Hi @PPolly
Kindly check APN settings if it is set for Telstra Internet.
Blanca
Community Team
Message 8 of 8
Discussion stats
  • 7 replies
  • 2545 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
