adambeg
Jan 29, 2022Follower
External antenna for B14 on Nighthawk M1
I have an external antenna connected to the TS9 ports and I'm seeing the "Quality" around 70 dBm. I'm not sure if higher is better or lower is better. If I disconnect the antenna I get around 40 dBm. But still I'm seeing packet loss when I ping google.
Any tips on what this "Quality" measure should be or anything else to try? I'm using FirstNet as my carrier.
I saw somewhere that the TS9 ports are only for certain bands, but I'm pretty sure B14 was included.
I can try to point the antenna a bit better maybe. Not sure if I should try tuning the other parameters like RSPR, etc.
No RepliesBe the first to reply
