× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
How to configure Aircard 340u for port forwarding?
incredibill
Follower
I can't find any means to access the advanced setup features on the device.
Any guidance is greatly appreciated.
Fred
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: How to configure Aircard 340u for port forwarding?
Hello Incredibill
Try log in into the Aircard by typing 192.168.1.1 or 192.168.0.1 into the web browser then it should ask you to login in defaults are usually Username:admin Password:Password. If this dosnt work you may want to find the default gateway of the device and then type that into the web browser. Then you should be able to go to settings then router then port forwarding. You may want to contact ATT for more support.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 5094 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
