- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is there a way I can force 3G on Netgear LB 2120?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I seem to have problems with the 4G connection, as the router disconnects constantly. Is there a way to force only 3G connection in the LB2120?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is there a way I can force 3G on Netgear LB 2120?
Hi SergioH,
Sorry there is no configuration to have the LB2120 3G only. I just wanted to double check. Is your LB2120 device's firmware up to date with the most current firmware?
Please let me know. :]
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Jason,
The LB2120 is up to date, we checked for updates but it said it had the latest firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi SergioH,
Thanks for your response. Did you do a factory reset on the LB2120 after you updated it to the current firmware? If not, then please proceed with the factory reset?
Please let me know if this worked :]
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi SergioH,
I just wanted to check up on you and see if your issue has been fixed. :]
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, Jason,
I am afraid the problem was not solved, we have had to change the router and use one from another manufacturer that let us force 3G connection always, and this way the connection is stable.
As 4G connections are unstable in some places, it would be important if in future firmware updates of the LB2120 it allows the selection of 3G/4G, 3G only or 4G only.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi SergioH,
Sorry to hear you were not satified with the LB2120 model. He did have other models that fitted your needs. The LB1120 is able to select which bands to only use.
If your new device is not compatible with you, then please take a look at our LB1120 model.
with that you would just need to go under Settings > Mobile > Preferences > Network Mode.
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the LB1120 and would also like ot force it to the 3G band. Under Settings > Mobile > Preferences > Network Mode the preference is on automatic and cant be changed. is there a way around this?
Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I haven't found a way to force the 3G connection, in fact I have had to use another manufacturer's router because there is no way to make this one work with a faulty 4G connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i to have the same problem with 4G. What modem did you go with to force to 3G?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Everyone,
Currently it is not able to select a band. I will forward this to my internal team and they will review the idea for consideration.
Thank you. :]
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi, perhaps in cellular panel, try to select manuel band et select other than lte.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is a severe design flaw by Netgear to exclude such an essential feature.
Currently on my phone I am getting abysmally poor download speeds, less than 10Kbps on LTE, but much better, although still poor speeds on 4g, 5Mbps.
So of course the Netgear modem in this particular location is essentially useless. A useless pile of junk simply due to the exclusion of a very basic and essential feature.
Netgear should be ashamed for such an oversight. A clear display of ineptitude and lack of understanding or any real world testing.
Since it's been over 4 months since this has been suggested, and no such feature has been added, I doubt we will be seeing any firmware update that might fix our defective useless modems.
Looks like I'll have to return this modem and purchase a new one from a manufacturer that actually knows what they're doing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I have the same problem I use fixed IP SIM and I use IPsec VPN with this router in bridge mode and it works really well, but I am in location where is very unstable 4G network. Sometimes is very fast, but sometimes almost 0 speed, 3G goes slower, but enough and very stable. In these time router try to go on 4G and this is bad for me and sometimes goes 3G then is everything fine. So the idea of the router for this usage is very good, but this feature is last think which I am missing, after that the product will be really good for me.
There is Network Scan button, but it only scans and restarts router, and than there is no options only that button. So if it is possible, please add this feature of selecting 3G, 4G or automatic mode to the next firmware update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was playing around with the 'Netgear Mobile' APP and in it you can choose some modes with it for the LB2120, LTE/3G ect.
Using this you can force 3G only, I would really rather be able to do proper band selection or have the proper
Telnet commands to lock bands on this thing though. Like I can on pretty much every other netgear 3G/LTE modem I have!
(320u/790s/800s)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wish I had found this post a fortnight ago before I wasted my money and bought an LB2120. I’m got exactly the same problem.
Netgear, why are you not listening to your customers? There is clearly a deficiency in your products configuration that is available in the most basic of cellular modems and routers. Why have you not included the band selection feature?
while we wait for your response, can anyone recommend a suitable device? - must have the Ethernet port.
lastly, has any clever person worked out how to use telnet to achieve the configuration we are looking for?
Thanks and regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry I should have edited my last comment...all of which still stand. I have managed to borrow an access point to run the app referred to above (thank you by the way).
Still waiting for the firmware release though so it can be done properly.
thanks and regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can telnet to it via the IP and port 5510, I have found some commands to use but the band selection commands doesnt seem to work properly.
AT$QCBANDPREF=?
$QCBANDPREF: (0-1)
AT$QCBANDPREF=1,"33"
$QCBANDPREF=1,"33"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. That’s great info to have.
The above method via a wifi router and the app has done the trick. Forced to 3G and sitting happily on 3 signal bars. Performance reasonable considering my location so hoping the settings will stick but more importantly I hope Netgear bring out the firmware update so others are not as imapacted.
cheers
