Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
LAX20 4G - 5G wi-fi is on and active but 5Ghz led is off
maxFerr
Hello, my LAX20 is ok, in LTE mode with Coop Voce as provider. All is fine, the 2.4 and 6Ghz bands are active and connect ed by cell mobile , with non problema.
BUT the led light is off, as in the foto .
I have read manual and google search , with no successi. Can you help me, ? Thanks
Message 1 of 4
Accepted Solutions
rcpax
Luminary
Rif.: LAX20 4G - 5G wi-fi is on and active but 5Ghz led is off
Did this just happen? Did it used to work just fine and all of a sudden the 5GHz wifi LED died? Try saving a backup of your settings, and do a full factory reset, and start from scratch and see if you can get the 5G wifi LED to work. If it remains dead even after a full factory reset, it could be a HW problem. unlikely but not impossible.
To be honest, since your network works fine on both radios (2.4 and 5) I would not really worry about it.
Message 3 of 4
All Replies
maxFerr
5 Ghz, sorry the mistake
Message 2 of 4
rcpax
Luminary
Message 3 of 4
maxFerr
Thanks for the response. Yes, All works fine, only the led (on 5Ghz) is off, mayby a factor failure. Because all the LAX20 functionality are good, i keep Your suggestion 'dont'worry , be happy'. Thanks for all, Max
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 168 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
