Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Lte
amrut627
Lte
I’ve set up a system with the Netgear LM1200 a sim modem that runs on lte. I plan on using it as my home internet. My question is should I get visible+ or visible for the sim?
Message 1 of 4
Guru
Re: Lte
No clue what visible/visible+ is. Is that the ISP provider for the sim?
Message 2 of 4
rcpax
Luminary
Re: Lte
Visible Wireless is an MVNO that uses Verizon's network. I cannot comment on the specific plan to use though, as I don't use this network.
Message 3 of 4
JBish
Re: Lte
The MVNO plans are lesser service (priority) than say verizon,att tmobile direct accounts regardless of the descriptions that you get the same service (you don't). Being as your device is not going to utilize the 5g signals regardless of plan... If wanting best bang for your buck... Upgrade to a 5g modem and then go with the "+" plan.
Regards
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 502 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
