× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
M6 Pro stuck in a reboot cycle
DARK66SABER
Tutor
So I have an M6 Pro through AT&T on a first net sim. My issue started recently after a firmware update. Prior to the update, I had no issues whatsoever. Now it seems the device is stuck in a reboot cycle where it either will fail to fully power on or if it does power on, it stays on for anywhere from 1-5 minutes then initiates a reboot. I’m new to the device and how this stuff works so any help would be appreciated.
Message 1 of 12
Fidgety
Re: M6 Pro stuck in a reboot cycle
I have a similar problem probably from the same update a few days ago. There is a tiny button under the cover to reset it but it didn’t work for me. It’s the size of a paper clip hole . I feel I might just have an over priced paper weight now.
Message 2 of 12
DARK66SABER
Tutor
I’ve tried everything that I can possibly think of from using the reset button multiple times, to running it with the battery in, running it with the battery out on AC power, trying to force a software update and nothing has seemed to work. I’ve seen other threads where people have the same sort of issues but there seems to be no solution. I have noticed that when I boot it without the SIM card inserted it boots right up and performs as it should, but it has no service connection due to the SIM card being out. I’m stumped and I don’t want to keep paying for something that I’m not getting any use out of.
Message 3 of 12
Blanca_O
NETGEAR Moderator
Hi, All,
Our engineering team is aware of the issue and is currently investigating and working on a fix. I will be sure to update the thread as soon as I can.
May I also request for the following information:
- Location (City, State)
- Are you using a FirstNet SIM? Have you tried another SIM?
- Device SKU (e.g. MR6500-100NAS)
- Firmware version
Blanca
Community Team
Message 4 of 12
Fidgety
Message 5 of 12
LilReAsoN
Guide
Did you guys figure it out yet?
Message 6 of 12
DARK66SABER
Tutor
So I’m not sure if I did something to fix it or what but mines been working without the constant reboot cycle for approximately a week now. It does restart here and there but not nearly as much as it did when I originally made this post.
Message 7 of 12
JT240Z
Luminary
So, what did you do to fix it?
Message 8 of 12
amhbbn
I have a Netgear Nighthawk M6 Pro. Model MR6500. Firmware version NTGX65_10.01.38.00.
I am based in the United Kingdom. Using a UK SIM. The name of the company who provide the SIM is ID Mobile. The router is rebooting around on average every 10 minutes. Although sometimes less than 10 minutes.
Seems to be working fine in getting a connection to the mobile network. I can run 4k video off youtube no problem. Then without warning the router will go into reboot cycle.
Message 9 of 12
cogim84
If your M6 Pro is stuck in a reboot cycle, try these steps:
  1. Disconnect the device from power.
  2. Remove any recently installed WordPress plug-ins.
  3. Restart the device and see if the issue persists.
Message 10 of 12
JT240Z
Luminary
Did you do the initial boot fix with or without a SIM card installed?
I've recently acquired a MR6500 "unlocked" that is supposedly was doing the reboot cycle.  I picked it up cheap enough to make it worth my while to see if I can fix it.  When it arrived, the battery was too low to power up the unit.  When I plugged it in, I got a message informing me that the battery was too low to boot and needed to be charged. It's now charging without a SIM card installed and is charging as expected.  I was able to get to the home screen after complaining that the SIM was not installed.  So far, I have not seen it reboot.   When I did get to the home screen, I was able to confirm that someone did have it powered up long enough to change the WIFI network name and password.  It obviously has not been factory reset before me acquiring it.  Now waiting on the "boot loop" software to become available before I proceed.
Message 11 of 12
Fidgety
Just install the battery. Done
Nobody just said it point blank.
Now I have
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 2885 views
  • 1 kudo
  • 7 in conversation
Announcements
Orbi 770 Series
