× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
MR1100 Nighthawk M1 Compatibility with Home Routers Model?
djt2020
Guide
MR1100 Nighthawk M1Compatibility with Home Routers Model?
If you’ve used the M1 long you may have noticed that it doesn’t play well with other routers via the Ethernet port. With the M1 set to IP Passthrough on and the DHCP turned off what models of router have you found to be compatible? I think this would be a valuable resource for many people. Thanks for your input.
I’ll begin the list with the TP Link Archer A7 AC1750.
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 895 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi 770 Series
