×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
MR2100-EUS - BUFFERING ON SMART TV
Fritto58
iL ROUTER con LTE WIND, anche due tacche su 5, ha un ottima velocità in DOWNLOAD sempre > 100 Nbps e UPLOAD > di 15Mbps. Non ho problemi con SKY, Netflix, DAZN e ovviamente con il PC, ma con lo SMART TV con app's Video, va spesso in Buffering. Si puo risolvere con qualche modifica di parametro sul Router? Prima con Vodafone FWA con dati di veocità piu bassi in Dowload, questo non accadeva.
Il Router collegato via LAN al TV
Grazie per il supporto.
Model: MR2100|Mobiler Router Nighthawk M2
Message 1 of 5
Accepted Solutions
JohnPeng
NETGEAR Expert
Re: MR2100-EUS - BUFFERING ON SMART TV
Could you please try connecting your Samrt TV via WiFi and see whether the issue goes away?
Thanks
John Peng
Message 3 of 5
All Replies
Guru
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 5
JohnPeng
NETGEAR Expert
Thanks
John Peng
Message 3 of 5
Fritto58
In Wi-Fi buffering goes Away. I do not understand why, buy it works. Il you do not mind please could you explain? In Any case thanks a lot
Message 4 of 5
JohnPeng
NETGEAR Expert
Based on your descriptions, the issue is interoperational issue between the TV app and Ethernet connection. It requires logs to really find out what is the real issue.
But based my own experiences, most likely the TV app is to blame. I have a smart TV. the built-in app can't access my NAS, but a third party app installed on the same TV can.
Thanks
John Peng
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1063 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
