× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
MR2100-EUS - BUFFERING ON SMART TV
Fritto58
The mobile Router operating with WIND LTE, has good performance with PC, Netflix, DAZN and SKY, but often goes in buffering using a video IPTV app on SMART TV.  Speed test is good with dowload >100Mbps and upload > 15Mbps, despite LTE signal is only sufficient 2 on 5 max.  This problem was not present using a Hauwei router with FWA (Fixed Wireless Access) Vodafone, which by the way, had minor performance in terms of  download performaces < 100Mbps.
There are some solutions or parameters to be modified in the MR2100 router, to eliminate the buffering?
Thank you
Model: MR2100|Mobiler Router Nighthawk M2
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 485 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
