- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
MR2100 – Nighthawk M2 Mobile Router Firmware Downgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having issues since the latest firmware version so I would like to do a rollback. However I can't seem to find previous firmware versions for my device. I am looking at the following page to find older versions: https://www.netgear.com/support/product/mr2100#download
Is there another place I can find older versions? The reason I want to downgrade is that I can't seem to access my IPcameras anymore using 2.4ghz wifi, only 5ghz, which is extremely weird because 2.4 was working fine before the upgrade. I've tried factory reset, changing the bandwidth from 20mhz to 40mhz and tried changing encryption but it nothing seems to make a difference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: MR2100 – Nighthawk M2 Mobile Router Firmware Downgrade
Is the 2.4Ghz band enabled? I know that it's off by default on my M6 and needs to be reenabled after a factory reset. Just a thought.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
