× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
MR5200 connection to 5G SA (stand alone) network possible?
OneTen
Is the MR5200 able to connect ot a 5G SA (stand alone) network? The data sheet is not very clear at that point. "Latest 5G Technology: 5GNR Sub 6GHz (N)SA" The term (N)SA gives me some worries. I'd like to get confirmation on this topic before I spend the money.
Thanks
Marcus
Message 1 of 8
TeeJay74
Virtuoso
Re: MR5200 connection to 5G SA (stand alone) network possible?
If you mean the M5 EU version, I wouldn't worry because these are firmware version things.
Message 2 of 8
OneTen
TeeJay74, thanks for your answer.
I totally agree that the firmware is crucial, as the login procedure to a 5G SA network is different to the 5G NSA procedure, which basically relies on a 4G backend on the carrier side.
Nevertheless `don't worry' is not yet the 100% answer I'm looking for. Can anyone in the community confirm that the MR5200 really works in a 5G SA network (n78 band should be o.k. according to the specs)?
Thanks a lot
Marcus
Message 3 of 8
TeeJay74
Virtuoso
Do we have commercial 5G SA deployments in EU area yet? That must be found first, RAN side first, then terminal side.
Message 4 of 8
OneTen
I‘m looking for a device to be operated in a private 5G SA network. I‘m sure we will have a 5G SA 😉
Message 5 of 8
JohnPeng
NETGEAR Expert
Currently, MR5200 EUS doesn't support 5G SA mode.
Thanks
Message 6 of 8
OneTen
Thanks for the clarification, is there a timeline or roadmap availble until when the MR5200 will support 5G SA networks?
Message 7 of 8
yellowtao
You know, in China and Hong Kong, most base stations have been changed to 5GSA mode, and NSA mode has been cancelled. I bought this router and now I can’t connect to the 5G network. Now I just want to know, when will Netgear be able to upgrade the firmware to support 5GSA mode, because Qualcomm X55 fully supports SA mode, please help me
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2063 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
