× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
MR6110 does not provide the required speed, (UPDATE)
Banditor
I have had the device for several weeks but only recently did a plan that includes 5G
There is a 5G service in my area and it shows on the device that I am on 5G
But if I do a speedtest I get a rather low result - (between 3 to 80 mbps max-which is the range I would get when I was on 4G)
On the other hand, if I do a speed test with the same SIM on my iPhone in the same location, I get 300mbps+.
I tried to do a reset or change to 5GHZ it didn't help
To solve the problem I tried several things
*contacted the SIM provider - they said that there is no blockage on their side
*updated the software to the latest version - it didn't help
* Reset the device - didn't help
*I tried changing the IMEI - it didn't help either
Attached is a screenshot of the current version
Message 1 of 2
Banditor
Re: MR6110 does not provide the required speed, (UPDATE)
@JohnPeng
I can send you model.json if that helps.
I would appreciate it if you could help
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 134 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi 770 Series
