Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Max USB disk size for M2
henrydip17
What is the largest capacity USB disk drive that the MR2100 Nighthawk M2 supports? Will it support 4gb?
Message 1 of 4
Re: Max USB disk size for M2
There may be a few clues here:
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
But those lists are far from complete and not up to date. There are just too many option s out there to maintain a comprehensive list.
You might get better advice in the section given over to your device.
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
Message 2 of 4
henrydip17
Largest USB disk you can use with M2
Message 3 of 4
henrydip17
Thanks. Have posted in correct area.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 682 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
