× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
NETGEAR Model: MR5100
rbms2022
Follower
Purchased two of these new on yesterday from Best BUY, activated them at the AT&T corporate store and the NETGEAR Model: MR5100 Doesn't seem to have internet through the Ethernet port? Has anyone else had this issue?
Model: Dual Band
Message 1 of 9
Guru
Re: NETGEAR Model: MR5100
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
Message 2 of 9
MGPhoto1984
Has anyone configured the MR5100 to use the ethernet port to connect to a camera or computer?
Message 3 of 9
JohnPeng
NETGEAR Expert
Ethernet port should work out of box. No extra settings are required.
You can try connecting a computer to etherer port for testing.
Thanks
Message 4 of 9
diamono
Did the issue with ethernet ever get resolved.  I am experiencing the same issue.
Message 5 of 9
JohnPeng
NETGEAR Expert
Could you please explain your setup in detail and what the issue you are seeing?
Thanks
Message 6 of 9
steveXXX
Apprentice
This worked for me:
  • MobileRouterSetup.pngSpecifically:
  • set tethering to "charge only"
  • disabled ethernet standby
PS: as of 2022-02-15 08:20 MST the above image is only shown as a "caution" icon.
It is: Settings > Setup > Mobile Router Setup
Message 7 of 9
diamono
Thanks SteveXXX.  I found that that if I turn the IP passthru on (which disables wifi),  that the ethernet cable would work.  I'll try the method you described too to see if it works.  It would appear that to get the ethernet cable to work, wifi has to be disabled.
@steveXXX wrote:
This worked for me:
Message 8 of 9
steveXXX
Apprentice
@steveXXX wrote:
This worked for me:
With my settings wifi is still available.  I can attach my phone to the netgear wifi to get internet on the phone via the M5.
Message 9 of 9
Discussion stats
  • 8 replies
  • 2243 views
  • 1 kudo
  • 6 in conversation
Announcements
Orbi 770 Series
