- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NIGHTHAWK M1 Telstra Firmware ????
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bought this M1 device to replace the AirCard 810S, also known as Telstra Wi-Fi 4GX Advanced III and DC112A
I bought the deivce because our landline sped is only 4mb and NBN is years away.
I get good connection speeds with the 810s typically 90mb down and 30mb up rather consistently. I have an extrernal antenna. Have random issues on occasions with pages not loading etc, but 90% of the time it works fine. Have wondered if it is DNS issues, firewall issues or even enviromental. A friend with the same unit has said that he discovered that there is a underlying issue with the device that Netgear has confirmed.
The M1 in the same envrioment is typically very poor. Avg speed is 20mb down / 8mb up
Power issues restarting when connected on the network.
I have been dissapointed with this unit and are close to returning it.
Before I do that is a firmware fix far away ? Right now I'm using the current Firmware of the device as it shipped. Hard V1.
Does anyone from netgear have any insights to when this device might get a firmware upgrade ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NIGHTHAWK M1 Telstra Firmware ????
Hi chefben,
Keen to get some further information from you in regards to this isuse:
1. Are you using a Telstra SIM or a SIM with another carrier?
2. Have you also got your external antenna plugged into the M1?
3. When you performed your speedtests was it using speetest.net and if so, were you using the same speedtest.net server as the test you did with the AC810S?
4. Have you only got WiFi clients connected or are you also using the Ethernet Port, USB port or SD card slot?
5. Is the device constantly plugged into a wall adapter?
6. What is the current and battery temprature showing under settings - diagnostics?
ArodiD
- Mark as New
- Bookmark
- Subscribe
- Permalink
Answers to your questions...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello.
I was also interested in the firmware for my device MR1100!
On my device the screen constantly saying "Detecting service" (see attached). Are there any other firmware? Ready to become a beta tester to test the networks of other operators in Russia.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had a Nighthawk M1 for a month after being advised by Telstra that this would make a good fallback whilst they fixed the firmware issues on their Gateway Pro / Netgear V7610.
Results were intermitant at best, only able to get link status 1 in five times and sometimes not at all despite however many times I patched / unpatched. I tried Cisco 887 router, desktop, forcing speed on NIC.
After 4-5 weeks of frustration, tech calls and a formal complaint, Telstra agreed to take it back and waive all charges.
It is a spectacular concept but ethernet justn't work and 4G performance is no better than aircard or MF910 until the base stations and backbone are upgraded (dependent on where you live)
Personally I suspect Telstra has diddled the firmware with a constraint so that it only works with a desktop (not switch) but that the restriction did not implement well. I have no inside information to support this theory by the way - just conspiracy 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see no answer to the question is there, or when is, a firmware update available for this unit ? Can someone please tell me ?
I have a unit that has lost all WIFI broadcast. Brand new, worked for 2 days, then no wifi broadcast. still works through ethernet perfectly....can still access wifi settings in setup, but nothing getting broadcast,,,nada, zero, cannot use wifi....have done the usual, factory reset, removed battery and sim, result is exactly the same no wifi broadcast, but internet access works fine through ethernet.....I say it's faulty ,,,,big time....any one gonna tell me different ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Take it back quickly - before it gets too hard to return!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your patience.
A firmware update (NTG9X50C_10.16.04.04) was recently released.
We try to release updates only when there's been a significant amount of changes. It's not much fun installing very regular updates that usually have no changes relevant to you so we prefer fewer more meaningful updates.
If you're still having issues give this update a try and let us know how you find it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Won't help me. I took mine back and got a refund after repeated efforts to diagnose the ethernet problem.
I am surprised you haven't pulled this firmware release as well after all the problems not recognising Telstra SIMs in them...
Upgrader beware I guess...
- Mark as New
- Bookmark
- Subscribe
- Permalink
That incorrect display appears to be a browser caching issue. My Dashboard wasn't displaying properly and yet after clearing the cache it then displayed fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bet you trying to use Chrome for a browser.
This version of firmware has been completely botched for Chrome. Very poor QA.
Try Firefox, IE or Safari.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interestingly when it wasn't displaying properly for me in Safari, I opened Chrome and the Dashboard displayed fine in that for me. I then cleared the recent cache from Safari and it displayed fine in that as well.
I'm using Chrome version 60.0.3112.90.
Have you tried clearing the cache in your web browser?
Web browsers cache websites so they can load them faster. However you don't want this for a web admin page especially when it has undergone a fair bit of change as a mixture of cached stuff from a previous version and non-cached current stuff can lead to it displaying weirdly.
Updates go through extended testing and we don't support beta versions of web browsers. Chrome 60 was only released a few weeks before the latest M1 firmware update.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
