× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear MR1100 dead not working
SHADOW_KSA
Guide
hello
my router Netgear MR1100-100EUS it's keep rebooting and not working if i put battery it's not rebooting it's like dead
6 time rebooting then stop working
in the video it's without battery
please help
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 8
Guru
Re: Netgear MR1100 dead not working
Have you tried a different charger? it wouldn't be the first time a bad charge wasn't providing enough power to run a device. It usually takes the most power during bootup.
You also might need to reset it if its been crashing for so many bootups. Page 71-72 of the manual has options for resetting using the button or through settings.
https://www.netgear.com/support/product/mr1100
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 8
SHADOW_KSA
Guide
i tried 3 a different charger and not work
Message 3 of 8
SHADOW_KSA
Guide
I replace battery from another device and my device not working still same problem
another device with my battery work fine !!
Message 4 of 8
TeeJay74
Virtuoso
Hi,
Have you tried rebooting without SIM card ?
Message 5 of 8
SHADOW_KSA
Guide
Yes I tried
Message 6 of 8
TeeJay74
Virtuoso
Hi,
Your device needs service evaluation, current situation looks pretty bad.
Message 7 of 8
rajamid
hi had the same problem the router just reboots after the netgear logo diappears , then i opened the device and reballed the  emmc and qualcom chip now it worked fine , its bcoz over time the soldering pads get  weak it needs reballing of the ic .
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 6590 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
