× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear MR2100-100EUS firmware look
galal
Look for a software netgar m2 hanging on the company logo
Message 1 of 12
Blanca_O
NETGEAR Moderator
Re: Netgear MR2100-100EUS firmware look
Hi @galal
Welcome to NETGEAR Community!
Kinldy take out the SIM card, reset the device, re-insert the SIM card and let it power all the way on then check for updates.
Blanca
Community Team
Message 2 of 12
galal
The router hangs on the Netgear logo and does not open at all. I need its software. I searched for it and did not find it
Message 3 of 12
Ulwa51
I have the same problem, the router has been hanging for a few days, but only with my Simyo card from Orange Spain. the Mr 2100 works with a card from another provider. I bought a new device and it's the same with it. maybe there was an update?
Message 4 of 12
JohnPeng
NETGEAR Expert
Thanks for the information. We will investigate the SIM compatible issue. Will get back to you soon.
Regards
Message 5 of 12
JohnPeng
NETGEAR Expert
Please check whether the device can boot up with SIM card. Or do a factory reset and see whether the issule will go away.
Thanks
Message 6 of 12
galal
I want to update it, thank you
Message 7 of 12
JohnPeng
NETGEAR Expert
How are you going to update it if it can't be boot up? Your device may be on the latest already.
Thanks
Message 8 of 12
galal
When you press the REST and ON button, the word "DOWNLOAD" and "Update" appears on the screen
Message 9 of 12
galal
I want the update file from you brother, thank you
Message 10 of 12
JohnPeng
NETGEAR Expert
MR2100's upgrade file is different from other devices. You can nly use the file when the device can be booted up. The tool will not work when the device in emergency download mode.
Thanks
Message 11 of 12
galal
I need software for the router, I searched for it but could not find it
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 3153 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
