× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear MR2100 no wifi
Thomasishere
Hi team, Mr2100 was working fine, now the wifi doesnt seem to be working - the wifi tab at the bottom of the main screeen has an X on it. i have the latest FW installed as of this date, ive factory reset several times with no change.
unit was workig fine,  i plugged in an external HDD with it's own power supply into the M2 and was able to stream a few minutes of some video files. after this, the wifi seemed to be disabled as mentioned in the previous praragraph.
Unit is still connected to mobile carrier, and works with usb internet but no wifi.
please help
cheers
Model: MR2100|Mobiler Router Nighthawk M2
Message 1 of 10
Blanca_O
NETGEAR Moderator
Re: Netgear MR2100 no wifi
Hi @Thomasishere
Welcome to NETGEAR Community!
Please provide device SKU (MR2100-1TLAUS) and firmware version.
Using a device that is connected to the network, kindly access the router settings page, go to Settings > Wireless > "Broadcast Wi-Fi Name SSID" should be checked.
Please check as well if WiFi Standby is set to Disabled or Enabled.
Blanca
Community Team
Message 2 of 10
Thomasishere
appreciate the effort, but is there anything else other than the basics you have mentioned? restarted, resetted several times with no improvement.
cheers
Message 3 of 10
archery47
That option to "Broadcast SSID" under settings does not show up in the Netgear screen, Also should the WiFi Standy be set to "Disabled" or set to some time frame ....
The replies you wwre given were not specific enough and confusing ...
Message 4 of 10
AyeAyeAye
Apprentice
My M2 periodically does the same, master reset is the only thing that works.
Message 5 of 10
archery47
Appreciate the answer, but U have tried reset via pin to reset on modem, reset to factory frim Netgear website, and reset to factory from modem multiple times and none have worked..
Which one if those options SPECIFICALLY are you referring to ?
Message 6 of 10
AyeAyeAye
Apprentice
Sounds like one for @JohnPeng - need to send him your json file
Message 7 of 10
Blanca_O
NETGEAR Moderator
Hi @Thomasishere @archery47
Please provide the device SKU (MR2100-xxxxxx) and firmware version.
How many device usually connect to the network?
Kindly temporarily remove the battery and power on the device without the battery then check if it will broadcast WiFi network.
Blanca
Community Team
Message 8 of 10
archery47
Bianca,
Thanks for that info. Tried without the battery but no success.
SKU :    MR2100-1TLAUS
Firmware :     NTGX24_10.17.10.00
Message 9 of 10
kazuar
I have exactly the same issue with my brand new router. Nothing mentioned here worked. I think it’s a hardware issue and I will have to return my device back.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2053 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
