× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear MR5100 guest wifi keeps saying wrong password
kirdovada
Follower
Im a novice,, if even that with tech stuff like this.
I tried to integrate a mesh network, it didn't work,. I had changed some settings and then I had no wifi with the MR5100 hotspot. I have done 3 factory resets, renamed my wifi, etc. I got the main wifi back, but then anytime I try to log into my guest wifi or add devices to ir (i.e. pet feeder, wifi only tablet), it keeps saying it's the wrong password. I'm staring at the hotspot display as I type and it matches exactly. I thought the issues was the 'always on wifi which was off the previous 2 resets. I turned that feature on, and yet guest wifi is unusable.
Appreciate any help.
Message 1 of 2
Re: Netgear MR5100 guest wifi keeps saying wrong password
Join the club.
Let's start with what you mean by "integrate a mesh network".
The MR5100 is a mobile router/hotspot which isn't a Mesh device. That's a label slapped on routers and "satellites".
The MR5100 just provides you local wifi that things to connect through.
What are you trying to integrate the MR5100 with? Some other device(s) on your network?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 480 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
