Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear Nighthawk M1 vulnerability
lenl
Initiate
When will Netgear release a solution / fix for the Netgear Nighthawk M1 vulnerability as mentioned in the link below ?
VulDB 140070 · CVE-2019-14527
Netgear Nighthawk M1 prior 12.06.03 Web Interface System Command privilege escalation
https://vuldb.com/?id.140070
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 6
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: Netgear Nighthawk M1 vulnerability
Hi, All,
This has been brought up already to engineers. No security vulnerability has been found on our test.
Please check reference link:
https://kb.netgear.com/000061155/Security-Advisory-for-Firmware-Encryption-on-MR1100-PSV-2019-0055
Blanca
Community Team
Message 4 of 6
All Replies
Oxygene
Apprentice
Upgrading to version 12.06.03 eliminates this vulnerability.
Message 2 of 6
lenl
Initiate
But the Nighthawk M1 says there is no new firmware update Smiley Sad
Is there a way to manual download new firmware ?
Message 3 of 6
Blanca_O
NETGEAR Moderator
Hi, All,
Blanca
Community Team
Message 4 of 6
sena71
Tutor
lmaooo are you sure about that? then explain to me how im able to force a telnet session with the internal linux/busybox OS? smh you guys couldn't even be bothered to change the root password from the default "oelinux123"
Message 5 of 6
sena71
Tutor
https://imgur.com/a/Q0RJwNb
So tell me, are you absolutlely 100% sure there is no exploit?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3311 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
