× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear Nighthawk mr1100 how do I know if it is unlocked or locked to a carrier the SKU is 6420B
Trvr97
Follower
Message 1 of 2
celler
Guide
Re: Netgear Nighthawk mr1100 how do I know if it is unlocked or locked to a carrier the SKU is 6420B
If you are in the US, there is a good chance it is ATT.  You can go here:
https://www.att.com/deviceunlock/
and check to see if it is an ATT device and if it is unlocked. If you get past the first page without an error, then it is unlocked on ATTs system.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 6966 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
