× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear nighthawk m6 pro and hp officejet 250 printer
kpmmolloy
Follower
Hi there
ive just gotten the nighthawk m6 pro mobile router. I was trying to connect my mobile printer (hp officejet 250). However it will only connect to a guest network and not the parent network (doesn’t recognise it). Any idea how to fix this ?
Many thanks
Message 1 of 3
It isn't down to your Wi-Fi network to "recognise" a prin...
It isn't down to your Wi-Fi network to "recognise" a printer. All that is in the hands of the printer itself.
The usual way to fix Wi-Fi printers is to find the printer maker's utility, the software that runs on your operating system. Then use that to connect the printer to the wifi.
The router just broadcasts Wi-Fi. It is then down to the printer to play ball. There isn't much that you can do on a router that affects what the printer gets up to, beyond fixing it to a particular IP address. That can be useful but you shouldn't need it.
Where possible, using the WPS feature can simplify things.
How to Connect Your Printer to WiFi | HP® Tech Takes
Just another user with time on their hands.
Message 2 of 3
Guru
Re: Netgear nighthawk m6 pro and hp officejet 250 printer
are you using wpa2/wpa3 mixed mode for security on the router wifi?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 179 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
