×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear stuck during factory reset
cmaestas
Follower
Three  issues:   #2 is what i need immediately solved.
1.  Netgear randomly resets itself to factory default on a regular basis and i have to go re configure it as though it is new (happens once a month or so)
This set off a chain of events.  During the set up process it would not allow me to use the default password. So i did another factory reset by using a paperclip/button to start over.
2. Its been factoring resetting for 60 min and just sits there and is hung. Message says: "Factory Reset in progress.  Please do not power off".
Clearly this router is not resetting properly.  SHould i remove power even though it says not to?   A factory reset should take less than a minute.
Can anyone tell me what to do?
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 387 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
