×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Nighthawk LAX20
Cybertax
Nighthawk LAX20
Hi,
does the LAX20 support the so called WISP or EXTENDER Mode to take internet connection from a WIFI Hotspot and share it over the LAX20's own WIFI? If yes, is it possible over 2.4 GHz and/or 5 GHz?
Thank you!
Ralph
Message 1 of 2
Accepted Solutions
ErnestTheGreat
NETGEAR Employee Retired
Re: Nighthawk LAX20
Hi @Cybertax,
LAX20 does not support the WISP or Extender mode feature. LAX20 uses WWAN so you just use a SIM from ISP you subscribed to and it provides cellular connectivity on the WAN side there is no need for a hotspot. In layman's terms, the LAX20 has an LTE Module inside that allows users to get Internet over LTE/cellular network.
Message 2 of 2
All Replies
ErnestTheGreat
Re: Nighthawk LAX20
Hi @Cybertax,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1632 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
