× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M1 Battery charging
CTWanderer
Follower
I have a brand new Nighthawk M1 that I'm charging the battery before I get a SIM card and set up service. I've had the charger plugged in for over 24 hours and the battery is only showing about a 3/4 charge. How long does it trake to charge a battery in this unit? Over a day seems to long. Is not having a SIM card installed causing it to take longer?
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 3
Guru
Re: Nighthawk M1 Battery charging
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 3
JohnPeng
NETGEAR Expert
Please advise your device SKU name and FW version on the device. It is better to make sure your device is upgraded to the latest release first before checking the battery chaging again.
Thanks
John Peng
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1035 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
