× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M1 MR1100 - Remote WAN Admin?
frankwarrell
Guide
Hi Folks. Are there any plans to allow for remote WAN admin on a Nighthawk M1 MR1100? Presently it does not seem to support this, or DDNS for that matter. We are using remote IP cameras with this router via port forwarding which works great, but we're using the camera's own DDNS service and we can't login to the Nighthawk remotely. And we are using the telstra.extranet APN to give us this remote access for port forwarding to work.
Incidentally, in earlier firmware versions you could login remotely on port 80, but it would seem this was then closed in further firmware updates.
It's a great router but full remote access to monitor the unit and/or adjustments would be even better. And DDNS support too please!
Thanks.
PC
Message 1 of 4
Accepted Solutions
ArodiD
NETGEAR Expert
Re: Nighthawk M1 MR1100 - Remote WAN Admin?
Hi  frankwarrell,
We are investigating internally on this feature.  No ETA at this stage and no commitment to make it happen on this product.
Kind Regards,
ArodiD
Message 3 of 4
All Replies
frankwarrell
Guide
Is anyone able to answer this please?
I understand I'm not the only one asking for these features...
Thanks.
PC
Message 2 of 4
ArodiD
NETGEAR Expert
Hi  frankwarrell,
Kind Regards,
ArodiD
Message 3 of 4
frankwarrell
Guide
Ok thanks. Are there any other Netgear products which are Cat 16 LTE which support more industrial features like DDNS and remote admin?
Cheers.
Paul C
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 8223 views
  • 4 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
