Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk M1
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-11-11
12:21 AM
2017-11-11
12:21 AM
Nighthawk M1
I’m interested in this device. Can someone help me with advice on set up?
I wanted to run 100m of cat6 from the Ethernet port to a Netgear Ethernet switch. From there I wanted to run to PS4 and laptop. Via Ethernet , not WIFI. Will this device support this set up? Will I loose much data on 100m of cat6 into a switch?
Thanks in advance.
Thanks in advance.
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-11-11
05:25 PM
2017-11-11
05:25 PM
Re: Nighthawk M1
At a 100 meters your about 1/3 the max distance for a wired lan cable with cat6 you should be able run a 1gb speed the switch and the routers lan port speeds will be the main factor limiting the network speed on that feed. I see no problem with a switch off a router to share the network connection to other devices.
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-11-11
05:53 PM
2017-11-11
05:53 PM
Re: Nighthawk M1
1/3 or 1/1?
https://en.wikipedia.org/wiki/Gigabit_Ethernet
Message 3 of 3
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
