Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M2 Mesh Wifi setup
kingkudu88
Initiate
Hi,
I would like to create a Mesh Wifi with my Netgear Nighthawk M2 router.
Which Netgear extenders do you recommend?
Thanks and best regards.
Message 1 of 3
Guru
Re: Nighthawk M2 Mesh Wifi setup
I don't.
I'd recommend just picking up a mesh system like the MK or Orbi system and connecting it to the M2 hotspot.
The hotspots are designed for short distance wifi (hotspot). For that reason, if you're looking for whole home coverage, I'd use a full router/mesh system and just put the M2 in passthrough mode. Or leave it in router mode and the router/mesh system in access point mode (not the method I'd use)
Message 2 of 3
kingkudu88
Initiate
Okay, thank you! I ordered the Nighthawk MK63 Mesh.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 488 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
