× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M2 Telstra Xbox connection
Vandercoon
Follower
I have the Nighthawk M2 router, on my xbox it will connect to the wirless, but the I cant login to Xbox Live or download games etc, if i connect with ethernet cable, I can the connect to xbox live and download, etc, but I get Double NAT problem.
Id prefer to connect wireless if theres a solution for that, but if I need to connect wired then how do I set up the router so I dont get double NAT??
Thanks in advance!
Model: MR2100|Mobiler Router Nighthawk M2
Message 1 of 2
Blanca_O
NETGEAR Moderator
Re: Nighthawk M2 Telstra Xbox connection
Hi @Vandercoon
Welcome to NETGEAR Community!
Please try to disable and enable UPnP. Here's the reference link:
http://www.downloads.netgear.com/files/GDC/MR2100/MR2100_UM_EN.pdf [page 60]
How did you setup the MR2100?
Kindly check if MR2100 has public or private Internet IP address.
Blanca
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1109 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
