× Our systems will undergo a planned maintenance on Sunday, May 19, 2024, between 12:00 AM and 02:00 AM Pacific Time. During the maintenance window, you will not be able to log in to your MyNETGEAR account (including apps), renew a subscription, or register a product. However, you will still be able to use guest checkout to purchase a new product or subscription service. Updates will be posted to Status.NETGEAR.com. We apologize for any inconvenience this may cause.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M5 MR5200 EU does no longer connect to mobile network
Thomnet
Hello!
My MR5200 has been lying around unused for a while. Now I can no longer use it to access the mobile Internet.
It is constantly searching for a network connection, but nothing is found.
I also don't get a firmware update, although the version seems to be ok: NTGX55_12.04.17.00.
APN should be correct (Telekom):
internet.v6.telekom
PAP
telekom
tm
iPv4v6 (PDP-type)
IPv4 (PDP roaming)
Display shows "vodafone - not connected".
Several resets already done.
The SIM PIN entry works and is accepted.
Access to LAN works, offloading also for network connection.
What else can I try?
Message 1 of 2
Accepted Solutions
Thomnet
Betreff: Nighthawk M5 MR5200 EU does no longer connect to mobile network
I just checked on a photo that I originally had NTGX55_12.04.12.00 a few hours ago on it and nothing worked. Since I was able to get a LAN connection it seems to have updated on its own to NTGX55_12.04.17.00 - and now it works again after the 8764675th reset and a manual APN update.
Maybe that works for other users with old firmware: turn on offloading for LAN on the app and connect it - then do anything else. When it find the update this may help you to. Reset to newest APN of your carrier and restart again.
Good luck!
Message 2 of 2
All Replies
Thomnet
Good luck!
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 783 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
