× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M6 Pro (MR6110) as Modem
1WtRngoFan
Can I use the Ethernet port of the M6 Pro as a connection for a Netgear router and turn off the WiFi and thus and use the "other" Netgear (AX3000 or AX 3600) router as the primary connecting point for devices?
Message 1 of 3
Accepted Solutions
Guru
Re: Nighthawk M6 Pro (MR6110) as Modem
Yes you can.
you can either go into the MR6110 settings and put it in passthrough mode. or you could leave the MR6110 as router (with wifi off) and connect your other router to it with that other router in access point mode. I just did it on mine yesterday for trialing something.
Message 2 of 3
All Replies
Guru
Yes you can.
Message 2 of 3
1WtRngoFan
Thank you for confirming this... 😁🙌
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 7824 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
