× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M6 Pro
Thomtenh10
Nighthawk M6 Pro
Hello,
I would like to establish Internet access via the M6 for my existing WLAN with the mesh routers. The M6 should have switched off the WLAN and no DHCP server should run there. The mobile access is intended to temporarily replace the omitted cable modem access until the fiber optic connection is laid. Access should be via LAN cable. The M6 should work like a modem.
How do I configure the M6 for this?
Thank you very much for your help
Thomas
Message 1 of 3
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: Nighthawk M6 Pro
Hi @Thomtenh10
Welcome to NETGEAR Community!
Kindly access M6 Web UI, go to Settings > Advanced > Mobile Router Setup
set IP Passthrough to 'ON'
checked Ethernet 'Enabled'
Then connect an Ethernet cable to the M6 and to your existing router.
Blanca
Community Team
Message 2 of 3
All Replies
Blanca_O
NETGEAR Moderator
Hi @Thomtenh10
Blanca
Community Team
Message 2 of 3
Thomtenh10
Thank you.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1999 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
