× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M6 mr6110-1s4mes Doesn`t work on 5G N78 frequency on STC Saudi Arabia‏
Ahmed_alharbi
Hello, I have a Nighthawk M6 device, model mr6110-1s4mes, version NTGX65_12.01.16.00, but unfortunately it does not work with 5G on STC n78. I hope to find a solution to this problem, noting that I noticed that the problem is only with this company. I have another company that uses the n78 frequency and Frequency works on the device
Message 1 of 2
Blanca_O
NETGEAR Moderator
Re: Nighthawk M6 mr6110-1s4mes Doesn`t work on 5G N78 frequency on STC Saudi Arabia‏
Hi @Ahmed_alharbi
Please be informed that a new firmware will be available in the next 24-48 hours and be pushed to all MR6110-1S4MES (STC) units in the field.
FW: 12.01.31.00
PRI: 02.03
Blanca
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 619 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
