× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M6 - wanting to run without the battery.
tpepper
Follower
Purchased a Nighhawk mobile router - Model MR6110. Have been travelling for 12 months and it has been plugged to power pretty much all the time which has I think ruined the battery. Have ordered a new battery but to avoid this again it says in the power settings it will run with a power adapter without the battery. When I select the appropriate power mode and plug it in with the USB cable it came with it says I need a power adapter. I cannot find anywhere online what sort of power adapter you need to do this.
Message 1 of 3
Guru
Re: Nighthawk M6 - wanting to run without the battery.
As long as it has enough output, most USB chargers should work. I'd try a higher powered one and a good cable. I've used that exact model on USB power alone and it worked fine
Message 2 of 3
JT240Z
Luminary
Charger must be a Qualcomm Quick Charger 2.0 or higher from what I understand.
Message 3 of 3
Discussion stats
  • 2 replies
  • 177 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
