× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nightwawk M1 data offloading to public wifi
Sukij
Hi..
My mobile operator provide wifi hotspot
1.  Auto-login.  When sim card in the phone, it's automatically connect to wifi when it's in range.
2.  Login via Web login page.
I try to setup M1 to offload the cellular data to wifi hotspot, both Auto-login and Login via web using username and password just won't work.  Seems like it's unable to login to wifi hotspot.
Please help and provide recommendation.  I find only 1 topic concerning the public wifi in the community but it's also won't work for me.
Thanks
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 4
schumaku
Guru
Re: Nightwawk M1 data offloading to public wifi
It's not unable to login, it can't connect to a hotspot. These mobile routers can use either Mobile Data (WWAN) or wired/Ethernet based offloading - however, there is no wireless client to establish a wireless WiFi Internet connection to the hotspot.
Not aware that mobile phones can use a WiFi connection towards the Internet (regardless if EAP-SIM, form based auth, or any other direct WLAN) while concurrently operating as a wireless AP. When enabling tethering and the mobile phone hotspot, the WiFi access to the Internet is disabled.
Message 2 of 4
Sukij
Ummm??  I think we missing the point..
I mean Operator give me a SIM which able to use 4G or login to Operator WiFi hotspot.
When I put this SIM into my phone and if it find the Operator Wifi Hotspot in range (like in department store), it will automatically login to Wifi Hotspot and disable 4G.
What I expect is that if the put the same SIM into M1, and the Wifi hotspot is in range, M1 should automatically login to Operator Wifi hotspot, same as when the phone is in the phone or same as when I am at home, M1 will automatically offloading to my home Wifi router.
Message 3 of 4
schumaku
Guru
@Sukij wrote:
What I expect is that if the put the same SIM into M1, and the Wifi hotspot is in range, M1 should automatically login to Operator Wifi hotspot, same as when the phone is in the phone or same as when I am at home, ...
Perfectly understood. As I said: One one hand the M1 does not have the capability for offloading to a WiFi Internet (no WiFi client, and no SIM-EAP support), and on the other hand I'm convinced your mobile phones can't concurrently use the provider WiFi hotspot and serve as a WiFi AP for tethering. Essentially, the M1 (and the M2) are mobile phone platforms with some added capabilities.
You might want to promote developing this capability with Netgear on the Idea Exchange For Home
Message 4 of 4
Discussion stats
  • 3 replies
  • 2564 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
