× Our systems will undergo a planned maintenance on Sunday, May 19, 2024, between 12:00 AM and 02:00 AM Pacific Time. During the maintenance window, you will not be able to log in to your MyNETGEAR account (including apps), renew a subscription, or register a product. However, you will still be able to use guest checkout to purchase a new product or subscription service. Updates will be posted to Status.NETGEAR.com. We apologize for any inconvenience this may cause.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Question About Nighthawk® LTE Mobile Hotspot Router
kkinderen
I'm considering the purchase of a MR1100. My house only gets Internet via AT&T Wireless. I've been using the AirCard for a while now and considering upgrading. The AirCard plugs into a docking station that provides Ethernet connections.
I notice the MR1100 has an Ethernet connection but from what I read it is only used as a primary Internet connection with failover to wireless? In my house I have a mix of wired and wireless devices. Can I plug an Ethernet switch into the MR1100 Ethernet connector and be on the same LAN as the devices connected via wireless? Or is it really dedicated to the Internet-facing side only?
Thanks,
Kevin
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 2
W1lliam
Virtuoso
Re: Question About Nighthawk® LTE Mobile Hotspot Router
You can either connect another Router via the Ethernet port, or a Switch. But suggest to have another Wireless Router as your primary home router, to have better WiFi coverage, while MR1100 set as LTE modem.
William
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 857 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
