Wdhelmet's avatar
Wdhelmet
Follower
Oct 21, 2022
Range extender compatible with AT&T mobile hotspot Nighthawk M6 Pro
Is there a compatible Wi-Fi extender for this mobile hotspot. I’ve tried 2 different Wi-Fi range extenders and they both would not recognize my AT&T Wi-Fi. During set up . Very frustrating so help would be appreciated. I have literally 1 day left before I can return it unless I can get it working. Thanks in advance.
1 Reply
  • plemans's avatar
    What extenders have you tried?
    What method of setup are you using? (wps push button, using the app, using the installation assistant)
    Where does it fail in the process?
    What hot spot is it?
