× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
WIFI extension options for Nighthawk M2 router.
AlexinQLD
We live in rural Queensland and use a Netgear Nighthawk M2 router for WIFI access
We get poor cover coverage across the house and we would like to improve this?
We are considering two options:-
(1) Firstly, get an and plug it into the ethernet plug in the modem, or
(2) Buy a Nighthawk MK63 Mesh system
Any guidance would be appreciated
Message 1 of 6
Guru
Re: WIFI extension options for Nighthawk M2 router.
I'd would get a router or mesh system and connect to it.
The reason why is the why on hotspots/cell spots is limiting in how far the wifi can broadcast. Its part of its broadcast regulation since they're designed to travel.
If you get a router/mesh system, it doesn't have that restriction. Plus they tend to have more cpu/processing power and be more capable.
Message 2 of 6
AlexinQLD
Many thanks for the good suggestion
Message 3 of 6
AlexinQLD
Who you suggest buying either a Orbi or Google nest system?
Message 4 of 6
Guru
either. I haven't used any of the google products but I have the orbi's so that's all I can attest to.
Dongknows has done some really good reviews on mesh systems and its worth taking a look at his site.
Message 5 of 6
AlexinQLD
Thanks again
Message 6 of 6
Discussion stats
  • 5 replies
  • 669 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
