× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Wifi Extender compatibility with mobile hotspot router
Dani07
Follower
Is the Nighthawk® AX8 WiFi Mesh Extender, 6Gbps compatible with the MR1100 Nighthawk M1 Mobile router?
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 3
Guru
Re: Wifi Extender compatibility with mobile hotspot router
You should be able to add an extender to it.
Another thing you can try is the fact that hotspots aren't exactly known for their wifi range because they have to be portable.
And the MR1100 has an ethernet port. You could connect an old router/access point to it (router in access point mode).
That'd have better range/performance (depending on what you used) versus the hotspots wifi.
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
Guru
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
For additional extender help and information:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2396 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
