agold2009
Nov 06, 2024Aspirant
Will a unlocked Nighthawk M6 Pro ATT&T (MR6500) work on the Verizon network?
Hi Guys,
I was looking at buying a second hand unlocked ATT MR6500 and was wondering if is compatible with Verizon Wireless? I'm getting conflicted info, has anyone done this or is it even possible?
Thanks!
- rcpaxLuminary
I
agold2009 wrote:Hi Guys,
Thanks!
First, you will have to worry about getting it enrolled with Verizon. If you manage that part and get your device activated with them, it looks like there are a few bands on the MR6500 that will work with Verizon. Not the most optimal experience, but it would probably work just fine. I have tried T-Mobille with it and the band compability is far worse with T-Mobile, it still work "okay". I know what the T-Mobile network capacity is in my area and the MR6500, using B2 and B66 (no 5G sadly), is doing about 1/4 to 2/3 of the full speed when I have 5G signal. If you have extra cash, I suggest you invest in an unlocked model like the MR6150 or MR6550 for much better compatibility.
might try reading this post from one of the main mod's.
