- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
problem getting unlocked mr1100 to connect att
- Mark as New
- Bookmark
- Subscribe
- Permalink
Trying out a new internet reseller and wanting to use router #2 with that reseller.
Details:
Reseller #1 : Sent router #1 with ATT SIM card installed. Works fine.
Reseller #2: Allows BYOD, sent SIM card with their logo (not ATT)
Router #1 - MR1100 - on start up shows the ATT logo, assume is an ATT version
Router #2 - MR1100 - bought from Amazon, "unlocked" per the listing.
After login to admin, every single setting and check box is set to exactly the same on both routers
Router #1 will connect to LTE with either SIM card
Router #2 will not connect with either SIM
Is there something else I can try or is this a bad router?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: problem getting unlocked mr1100 to connect att
What model is this router#2? you can check on the back label after removed the battery and back cover, not every M1 (aka MR1100) model supports all the LTE bands in every country.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
