× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
web admin password not enabled
david70
Follower
Hello everybody, I have bought a aircard 785 mobile hotsport and when I try to set the administrator password in the web home page setting,  but it isn't enabled. Any suggestions, thanks.
Davide
Message 1 of 6
go4dutch
Re: web admin password not enabled
same problem here after upgrading last firmware !!!!!!
Message 2 of 6
DarrenM
Sr. NETGEAR Moderator
Hello go4dutch and david
I was able to test the 785 aircard I have and was able to change the admin password. You may want to try a different browser if its not working for you I used chrome and it work. next make sure you are logging in as admin so it allows you to change settings. if those dont work try to do a factory reset on the aircard. hope to hear your feedback
DarrenM
Message 3 of 6
DarrenM
If this issue is still happening can you give me some screenshots so I can pass them on to engineering
Thanks
DarrenM
Message 4 of 6
maggio
tried to uses several browsers: Safari, Chrome,firefox and IE
same result   since last automatic firmwareupdate  only the standard passwort will work and this is not changeable on webinterface.
There is only a Admin entry but no field you can place the cursor to put in an alternative password.
BR
Maggio
Message 5 of 6
DarrenM
I have passed this issue onto our engineering team they are currently working on a fix but I dont have a ETA on that ill post back once I hear a update on the fix. let me know if you have anymore issues or questions.
DarrenM
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 6446 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
