Orbi WiFi 7 RBE973
Reply
Blocking Fortnite
Retired_Member
Not applicable
Blocking Fortnite
Hi
I have tried to block an ongoing Fortnite session with Disney meetcircle on my Orbi RBK50 Setup. The gameplay just goes on so i suspects something wrong in the pause rules.
From the cli on the router I can see the following firewall rules:
iptables -L PAUSE
Chain PAUSE (1 references)
target     prot opt source               destination
ACCEPT     all  --  anywhere             10.123.234.1
ACCEPT     all  --  anywhere             anywhere             match-set circleservers dst
DROP       all  --  anywhere             anywhere             MAC B4:AE:2B:AE:CE:82
DROP       udp  --  anywhere             anywhere             MAC B4:AE:2B:AE:CE:82 udp spt:19132
Why is the sourceport 19132 defined in the UDP-rule, couldnt it just block all UDP-traffic?
Running firmware: 2.3.1.48
AJ
Message 1 of 4
Guru
Re: Blocking Fortnite
I would post about this in the Circle forum:
https://community.netgear.com/t5/Orbi/Go-Back-to-OPENDNS-Parental-Controls/td-p/1664998/jump-to/firs...
@Retired_Member wrote:
Hi
iptables -L PAUSE
AJ
Message 2 of 4
DexterJB
NETGEAR Moderator
Hi @Retired_Member,
Welcome to the community!
This has been reported to engineering and is being worked on. We will provide an update once available.
Dexter
Message 3 of 4
DexterJB
NETGEAR Moderator
Hi @Retired_Member, our latest update from engineering is that this is currently a limitation on the feature and may take a while to be resolved. They will continue to work with the Circle team.
Dexter
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2419 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
