Orbi WiFi 7 RBE973
Reply
Can't connect to circle
cchan8
Guide
Can't connect to circle message only with 1 profile. After deleting profile, devices moved to home and now, can't connect to circle message appears in home when try to edit the profile. Other profiles have no problem with editing and saving.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 5
DexterJB
NETGEAR Moderator
Re: Can't connect to circle
Hi @cchan8, Welcome to the community! You can try creating a new profile then move the devices there and check if the issue will persist. Let us know how it goes.
Dexter
Message 2 of 5
cchan8
Guide
Tried that. Now the new profile becomes can't connect to circle.
Message 3 of 5
DexterJB
NETGEAR Moderator
Hi @cchan8, thanks for the update. I have sent you a message. Please check your inbox.
Dexter
Message 4 of 5
cchan8
Guide
Please post solution.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1717 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
