Orbi WiFi 7 RBE973
Reply
Can't retrieve Circle PIN
Mikey0426
Follower
Hello-
Sorry for the repeat question, I see this question a lot but no answer other than PM requests.  I had circle set up through my Orbi, working well.  Then not sure whether it was a firmware update, a software update, or some other unknown event, but Circle was no longer communicating with my app.
I tried to log in again, but it went through the set up process.  I got to the screen asking for the PIN, which I couldn't get, clicked on "Only Admin" to get SMS, but it never came.  Resent, same deal.  Despite an hour of research, I don't know what to do next.  I can't access the App. Tried rebooting router, tried uninstalling/reinstalling app.
Help, please?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
DexterJB
NETGEAR Moderator
Re: Can't retrieve Circle PIN
Hi @Mikey0426, welcome to the community! Please check your inbox.
Dexter
Message 2 of 4
CrazyVetteGuy
I am having the same issue with my Pin after reinstalling the app. Could you help me our Dexter?
Thank you,
CVG
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 3 of 4
BGrind
I'm having the same issue. I've never used Circle but, would like to set it up now.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1408 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
