Orbi WiFi 7 RBE973
Reply
Circle Setup with R6700
gekoenig
I am trying to set up Circle for the first time, I installed the Android app for the inital install, it is asking me to scan the QR code on the bottom of the router and/or enter a 17 digit code. My router provides neither on the bottom. I can not install the Circle app without either of those. Any advice please?
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 3
gekoenig
Re: Circle Setup with R6700
I figured it out, there are 2 Circle apps, Circle 1st gen worked out for me.
Message 2 of 3
Guru
I believe the router is using the newer SPC controls which use the newer Circle 1st Gen:
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
Something to keep in mind.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBE973S and SXK30; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 851 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
